Marking selected points in a Graph
Is it possible to mark selected points in a XY graph ?
Lets say i have a XY graph which is made from an array. Now I want to hightlight a point with a ring or square point at specified index, say index  4 ; from the example below i want to hightlight the data points 12 & 54 See attachment.
I tried to use MAP to XY Coordinates Invoke but couldnt go further. Is there any idea to do it?
Nghtcwrlr
(5,390 Views)
(5,328 Views)
Hi!
I attached a VI snippet. I hope thats what you are looking for.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,321 Views)
Hi Christoph
Thanks for your help. I was already trying to use the Annotation property and ws succesfull in implementing it but only problem is that only the last value is being shown in the graph. See attachment.
I will try your VI now.
Nghtcwrlr
(5,306 Views)
Hello Nghtcrwlr,
best regards
Alexander
(5,300 Views)
I would just use a second plot with large points.
(5,268 Views)
