Mass compile in Windows 7 on SimpleErrorHandler.vi
i wrote some action in Labview 2011 that i want to use in Teststand with labview-runtime.
But some of them are not working and cant be loaded in Teststand. So someone told me to run a mass-compile.
I did this several times (also on complete drive c:) but with no luck.
Now i found out that only the vis that are using the "Simple-Error-handler.vi" are not working and cant be loaded.
When i delete this vi from my VIs then i have no problems any more.
So i opened the SimpleErrorHandler.vi manually in Labview and selected "Save All".
Then i get a popup:
Cannot save VI "FXP.xctl:fxpInit.vi"
The VI already exists and you do not have permission to replace it."
How can i resave it? I think the SimpleErrorHAndler must be also saved in Labview 2011 to be runable in the runtime2011
Thanks for help
(2,597 Views)
Just to close the Circle:
This Thread deals with the same Problem:
http://forums.ni.com/t5/NI-TestStand/Vi-not-running-when-using-NI-s-SiimpleErrorHandler-vi-TS2010/m-...
Regards!
Moritz M.
(2,580 Views)
