Master-slave issue. How to gently break and re-start the same while loop?
Quickly: My main aplication has two buttons Start and Stop which are handled by Event structure. Start should trigger start of testing (another while loop) which is programed to perform 1000 times.  However, due to fact that that test takes long time I'd like to have an oportunity to break that test before declared reapetations with Stop button
After break I'd like to collect results and to have opportunity re-start the same test loop with that Start button.
What is the best approach to program it?
K.
Message 1 of 8
(4,009 Views)
you may want to look into a state machine
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 8
(4,006 Views)
can u post your VI?
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 3 of 8
(3,988 Views)
Thanks for all answers.
The draft version of my VI is attached.
Cheers,
Message 4 of 8
(3,961 Views)
As a quick demo I modified your lower loop to operate as a slave to the upper.
The cases to the left wait 500 ms for a queue update and if no time out the command will switch to the desired mode. If Time out then use the previous mode.
The case to the right implements your mode Start, Stop or Exit. Only the Exit terminates the lower loop.
Have fun,
Ben
Message 5 of 8
(3,948 Views)
...adding to my previous post.
SEarch on "State-Machine". It sounds like you want your lower loop to be a State Machine (operates in one of many states) that changes states based on commands from the upper loop. Figure out how State Mahcine and queues work as seperate tasks. Then combine the two.
Ben
Message 6 of 8
(3,944 Views)
Thanks a lot guys.
I know how it works now.
K.
Message 7 of 8
(3,859 Views)
MimiKLM wrote:
Thanks a lot guys.
K.
Could you pllease post code that illustrates your solution?
This forum lives and dies by people posting answers as well as questions.
Ben
Message 8 of 8
(3,857 Views)
