Match Pattern Does Not detect "\" (backslash when back slash is given inside square brackets)
Match pattern VI does not detect "\"(back slash) when I give Back slash inside the square brackets, I'm attaching the sample code which I made, In this VI all the symbols in the square bracket except back slash are detected. Does anyone know what is wrong with the program.???
(3,135 Views)
Accepted by topic author Vinay_Kumar_M_S
Use a double slash [<,\\,>] inside the square bracket. It will be detected.
regards,
Nitzz
(Give kudos to good answers, Mark it as a solution if your problem is solved;))
(3,132 Views)
But why do we need 2 back slash to detect one????
(3,113 Views)
I think it's because the backslash is used in formats etc. For example \s for string.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,111 Views)
Even Deejay is right. That's the reason why ' \ ' can't be used alone in such functions.
Nitzz
(Kudos are always Welcome;))
(3,107 Views)
