Match Pattern Function does not seem to be doing what it is supposed to do. Can anyone help please?
I am trying to use Match Pattern Function to separate a string of different signals I receive.
I have cascaded 3 Match Patterns in order to separate 3 different signals from a string. It does not work properly. I have attached the test file herewith.
I am not sure if I am using wrong "Matching patterns'.
I used tab, newline and space to match the patterns.
(3,330 Views)
Your VI works fine. If you use Space as the Pattern in all three cases the results are Heartrate = "quick", Pressure = "jumped\sover\sthe\slazy\sdog.", and Temperature = "brown\sfox" This is what is expected for your test string.
Can you show us an example fo your data string and how you need to parse it?
Lynn
(3,330 Views)
You should eliminate the wires connecting offset past match to the offset of the next function. When you do that, you're telling the Match pattern to skip doing a match on the first x number characters. If the character you're searching for is before the offset, it will not be found.
(3,330 Views)
Dennis:
Thanks alot. You were right. It works ok when I eliminate the wires.
Thanks man.
(3,330 Views)
Dear Lyn
I discovered my error. I was supposed to eliminate the wires between the offset bits of one match pattern to another and it works fine then.
I appreciate your help however.
Thanks alot for your help.
(3,330 Views)
Dear Lyn
(3,330 Views)
