Match Pattern Syntax help
Accepted by topic author Huqs
Another loopless way using regular expression.
Ben64
Message 11 of 17
(3,059 Views)
Ben64, Thank you very much again.
Message 12 of 17
(3,056 Views)
Do you guys think you can further help me? This match pattern syntax was part of a bigger project.
Message 13 of 17
(3,040 Views)
If you are having a different issue (not part of the Match Pattern), then start a new thread.
Message 14 of 17
(3,036 Views)
Yeah, It's part of the same match pattern problem. I am building a VI that can load a certain type of CSV files. The file names are too big. What I am trying to do is break apart the file names and put the numerical values from the file names in Spreadsheet. Here's a snapshot of what the Input and Output I am trying to gain.
Message 15 of 17
(3,034 Views)
use one of the methods shown in the posts above, but inside a for-loop and do some (auto)-indexing
Message 16 of 17
(3,016 Views)
I would do something like the attached.  You can just put this inside of another FOR loop to iterate over the file names.
Message 17 of 17
(3,011 Views)
