Match Pattern does not function properly when searching for a null character
I'm using Match Pattern to extract a null terminated string from a response I'm getting from a device on a serial port. The VI is attached and below is a screenshot of the block diagram.
It works just fine with index set to 0, 1, or 2. When index is 3, I get the output shown below.
Why is Match Pattern not finding the null character?
Thanks!
(2,825 Views)
By the way, Labview 2011.
(2,824 Views)
Oh, I should also mention that the string control/indicators are set to hex display mode...
(2,823 Views)
Accepted by topic author Xooch
I'm a dope, need to remove the wire from the Offset control to the Match Pattern control.
DUH!
(2,822 Views)
