Match all characters excluding ones "inside the double quote"
@thols wrote:
\!\$abCD will work.
I usually use https://regex101.com to test regexes. It gives direct and clear feedback.
I like using https://rubular.com/ for RegEx testing.
Former Certified LabVIEW Developer (CLD)
Message 11 of 18
(2,364 Views)
Thank you for your idea but in your case, if I don't have the "Plus" + as the format of the expression, nothing can be matched. + ... + is just my example. I would like to match all strings (with some special characters I mentioned above) excluding the strings "inside the double quote"
Message 12 of 18
(2,344 Views)
Well, here's one way to get everything except what is inside quotes:
It's just what I came up with now but I'm sure there's a simpler way.
Certified LabVIEW Architect
Message 13 of 18
(2,339 Views)
I don't know if it's been improved, but that solution is very slow if the string gets big (it bit me in a project as i started on this job). It's better to send the 'index found' to the shift register and use it for 'start at index'. That way no string needs to be reallocated. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 18
(2,335 Views)
I did a test, the difference isn't very big nowadays, using index is some 10-20% faster and more consistant, but not a huge thing. 🙂
Qestit Systems
Message 15 of 18
(2,330 Views)
@Yamaeda wrote:...
/Y
Of course, how sloppy of me:
Message 16 of 18
(2,324 Views)
@thols wrote:
@Yamaeda wrote:...
/Y
Shouldn't that shift register be initialized?
Spoiler
It should.
Message 17 of 18
(2,317 Views)
I think this does the same:
Or, if you just want all quoted strings removed:
Message 18 of 18
(2,314 Views)
