Match pattern 4 in consumer producer loop
I currently have a consumer producer loop, and what I want to do is to add an element to queue if the element (picture), has a specific pattern (license plate). After that, I want to pass the image to the consumer loop, so I can use the vision assistant with it.
Can someone please help me?
(2,650 Views)
What help do you need?  Where are you having problems?
One thing to watch out for that is peculiar to Vision.  The purple wire is actually a reference to an image rather than the image itself.  So you can pass a reference to an image in one iteration, but it could wind up being overwritten with the next iteration of the producer loop.
(2,646 Views)
what I want to know is how to use the pattern match 4, and how to fix this consumer producer loop, because I can't see any image in both of the screens.
Thanks for your help!
(2,641 Views)
Hello  there;
I was checking your code...
The first issue you are going to encounter is going to be the data transmission... as mentioned above, you are passing the refference to a memory location where an image resides (not the actual image) and you are re-writting on the same location over and over again, therefore even if you have 5 images in queue they are all going to point to the same exact place.
Third, when using the database connectivity toolkit you should connect to a .udl (ODBC database) or a .dsn  (OLE DB) that configures the access to the database, if you use a string, you will get an error.
Before using the OCR algorithms I would recommend to set a refference or coordinate system; you can set it by identifing a refference or coordinate system. I am guessing this is where you want to use the match pattern VI; although I would recommendthe imaq match geometric pattern instead to locate the rectangle of the license plate; remember you need to train it first
You can find an example here:
https://decibel.ni.com/content/docs/DOC-30576
Hope this info helps
Greetings
(2,567 Views)
