Matching the column the database with the array
Hi .need help i have two array .one array(Array2) with the column name  and another array (Array3) with the values for the selected column.
Now i can insert the the column and its value in specified field in the database.
let say i have some other column which is not in the Array2..For example DR3,DR4...I have to store as CL in my database.
How to do that. plz help.
i attach the array pic in this.
(3,200 Views)
Hi jeyanthi,
you show the same error picture.
Can we continue here?
Mike
Message Edited by MikeS81 on 05-15-2008 06:37 AM
(3,190 Views)
Im sry i wrongly paste it .
(3,178 Views)
Hi jeyanthi,
I am not sure I completely understand what you are trying to do.   If you want to search for a particular element, you can use the Search 1D Array function.  Are you using the Database Connectivity Toolkit?
Jennifer R.
(3,132 Views)
