‎08-30-2019 08:00 AM
Racking my melon head to figure out how to do the math on calculating the time remaining for my gas bottles from pressures acquired on my NI-9237.
I would like to use around two hours of acquired data to calculate, based on this data, how much in minutes, hours and days is remaining.
Thanks in advance. 😎
Solved! Go to Solution.
‎08-30-2019 08:23 AM
This doesn't seem to be a LabVIEW question. It is a science question depending on a lot of factors you don't even mention such as how is pressure being lost from the bottle and at what rate? You might want to ask this on a science forum.
‎08-30-2019 08:28 AM
How do you delete posts here?
‎08-30-2019 08:32 AM
You can't.
