Mathematics in LabVIEW Power Programming VI's
It appears to do repeated subtractions of the entire denominator array.  When the difference is less than the denominator it stops.
I found some errors in your VI while trying to see if I could speed it up.  I now have it so  thoroughly broken that it never stops!  The tests in the while loop may be wrong. The algorithm (D3) says to repeat the test if r* < b, but you have it stopping the loop.  The q*v[n-2] > br*+u[j+n-2] may not be quite right also.  However, changing those still did not get it working.
Lynn
Message 11 of 13
(728 Views)
Now I am studying this book but I don't have CD, so can you send to me it.
Thank you in advanced!
my e-mail is: muaxuan0210@gmail.com
Message 12 of 13
(704 Views)
Read the posts.   Johnsold already said that the data on the disk is copyright protected so you'll need legal permission.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 13 of 13
(702 Views)
