Mathscript Array
I wanna use the counter in my While Loop to acces the values of my vector/array inside the Mathscript. However, I get this message error:
"Error -90026 occurred at Error in function V at line 1:  The indexes for a matrix indexing operation must be real, positive integers."
Also, the counter is an integer, so I don't have a clueof what is the problem. I will attach my VI so I can make myself more clear. Thanks in advanced.
Yours sincerly,
Guilherme Garber
(3,345 Views)
The issue lies in the fact that LabVIEW uses 0-based indexing for arrays and MathScript uses 1-based indexing. The integer counter you reference is indeed an integer, but it starts at 0. Since 0 is not a positive integer (and also out of bounds for array indexing in MathScript), you see the error message.
Grant M.
Senior Software Engineer | LabVIEW Tablets | National Instruments
(3,317 Views)
