Mathscript RT module
Hi Guys,
I have recently installed labview 2015 64 bit on my machine and im looking to get the corresponding mathscript RT module but i could not get one. Any suggestions on how to get on with the problem.
Tuj
(4,288 Views)
Look at the readme file https://www.ni.com/pdf/manuals/375325b.html under Installation Instructions.
(4,278 Views)
LabVIEW 2016 is the first version that supports 64 bit Mathscript RT. Since you are using LabVIEW 2015, you need to stick with 32bit LabVIEW if you want to use Mathscript. (details)
Why do you think you need 64bit LabVIEW. Typically 32bit is recommended, even on a 64bit OS.
(4,253 Views)
Your link is for the 2016 version. The same document for the 2015 version shows that 32bit LabVIEW is required.
(4,240 Views)
You're right.  I searched for LabVIEW Mathscript RT.  Found the help file for 2016, never noticed the OP stated they were 2015.
(4,236 Views)
