Mathscript replace m-file during execution
I want to change mathscript code during my application is running...
Therefore I call an *.m-file in the mathscript node. I can change the search path and so on but I can´t replace an m-file in the memory.
Any ideas??
 Thanks!
Christian
(3,266 Views)
You can't do that.
You can use a case structure to select a different Matlab Script node but the script the node executes must be known at compile.  Not run-time writable.
(3,243 Views)
Thanks Jeff!
Sure I can´t change the script itself. But I call an external function in an *.m-file... Is there any chance to change the m-file when labview is started already?
Christian
(3,225 Views)
LabVIEW actually calls on the Matlab runtime to execute scripts.  A call to a external m file might not break LabVIEW (given the data types of the inputs and outputs don't change)
(3,211 Views)
