Mathscript syntax error
I have a VI with a mathscript running on a PC with LV 2019. If I open the same VI on another PC with the newest LV 2019 (f1) the VI is broken because I have an syntax error. I cannot understand why. Can anyone help me?
Fabio
(3,353 Views)
Accepted by topic author fabio.int
Hello Fabio,
it seems that the tf function in your code is not recognized. According to the help, Control Design and Simulation Module and MathScript RT Module are required to use it; these modules are installed on my system, so the Run arrow is not broken.
Hope this helps!
Alessia
(3,306 Views)
thank you very much!!!
(3,295 Views)
