Mathscript using Reimann Zeta .VI
I have labview 8.6.1..the Reimann Zeta.VI  example fails for
a simple error 90051..but, how do you edit
the internally protected mathscript file....MCStatic_....XXXXX?
What is wrong with this VI...?
This example came with labview..It does not need editing to run.....
but it errors out when you run it...
JJB
(3,963 Views)
I ran this vi on two computers using the same software
Matlab and 8.6.1
It works on one computer but not on the other...it could be a path
difference..so far thats all I come up with..
Although, my symbolic matlab toolbox doesnt work with either computer...
(3,937 Views)
Hi labviewjoe,
Since this example runs just fine on one computer and not on another, it leads to me think that maybe the example VI on the computer that it does not run on has become corrupted somehow. I would suggest copying the VI and .m files from the computer that it works on and moving that copy over to the other computer and checking to see if it runs. The VI and .m files can be found at: labview\examples\MathScript\MathScript using Riemann Zeta.
Thank you for choosing National Instruments.
Aaron Pena
http://www.ni.com/support
(3,927 Views)
Accepted by topic author labviewjoe
Thanks for the help...I did copy all files over..
But, when I was playing around with
modifying the m files..just trying to
see if they were bad...I corrupted
them on purpose and ran the software vi...
a new error came up..for good reason....
Next, I fixed the m files back...not sure what
happened..but after that new reload...
It is working on both computers...interesting
lesson for me...I am glad I had two computers
to debugg or at least learn from...
So in the end, Im up running...the vi was
probably not loaded correct first....but
somehow it was fixed...
Thanks...Smiley Happy
(3,924 Views)
