Matlab DAQ: using I/O channels simultaneously?
Hi all,
I would like to acquire and output two signals on a
National Instruments 6035E board.
The purpose is to create a control signal based on the
acquired signal.
I'm having problems with the DMA and I wonder if
it is possible making such a thing using DAQ from Matlab.
Also, if you have any experiences (any shortcomings/advantages)
on using NI board (especially E series) from Matlab DAQ I would
appreciate if you could share it.
Paolob
(2,730 Views)
Paolob,
This is possibly with the MATLAB Data Acquisition Toolbox. The problem is
your hardware. The PCI-6035E is a low cost board and only has one available
DMA channel. You can set the 'TransferMode' property of either your analog
input or analog output object to 'Interupts' to use both of them
simultaneously (e.g. "ao.TransferMode = 'Interupts';"). I would recommend
setting this property on whichever object has the lowest sample rate because
it will cause a severe performance hit.
-Dave Tarkowski
On 22 Oct 2001 01:18:18 -0700, Paolob wrote:
>Hi all,
>acquired signal.
>I'm having pro
>Thanks
>Paolob
(2,730 Views)
