Matlab DLL vs Matlab script in LabView
     I have some question for those who successed to import the Matlab DLL's to  LabView  Smiley Happy :
 Is there significant time difference between processing the matlab routine thru the DLL  and between the Matlab script in LabView ?
 For the  RT   program that I am doing in LabView the time is very impotent, and as I  measured , the code writen  in Matlab script
 takes 10 times more then the same  C  code using DLL  ( 20ms.  vs 2ms.) . As I understand, importing DLL from Matlab to
 LabView is not so easy,  so before I "step at the deep"  I would like to ask, if I would have the  shorter time in Matlab DLL, than in Matlab script?
  Michael Shklyar
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(4,355 Views)
Hello Michael,
Are you actually running this application in the LabVIEW Real-Time OS?  The Matlab Script uses ActiveX calls and only works on a Windows Operating System.  Calling the dlls in Call Library Function Node would be a more difficult that using the Matlab Script Node.  You will need the function names in the dll as well as the parameter list.
Good luck
Steven T.
(4,333 Views)
Hello Steven,
Yes, we are using Windows. About the dll's - I am using it right now, but written at C.
About Matlab: it`s very nice idea to use tha Matlab mathematical power instead of writing the basic (FFT for example) algorithm at C,
 but  as I understand it`s not trivial to import the Matlab dll to LabView.This why I have  question about the time of execution. Smiley Happy
Michael Shklyar
(4,313 Views)
mishklyar,
That is a great question.  DLLs will be run in the runtime environment of the program that created them.  So calling the DLL in C will give you a good idea of the performance of the DLL.  When calling the same DLL in LabVIEW, you should get similar behavior with regards to speed.  So in short, you should see a performance increase by calling the DLL compared to your current method.
I hope this helps,
Steven T.
(4,292 Views)
