Matlab GUI loaded from within Labview
I have a GUI user interface that needs to be loaded from within Labview Matlab script.  In the script text, I simply have: "open test.fig".  The figure window appears, however, seems to be incomplete.  By that I mean certain structures (handles) was not initialized.  Anyway can tell me how to correct load it up??   Thanks.
Message 1 of 10
(6,534 Views)
Which version of Matlab and LabVIEW are you using together?
Jarrod S.
Message 2 of 10
(6,525 Views)
Labview 7.1.  I have two versions of matlab: 6.5 and 7.0.1, but I use matlab6.5.  This is verified by using 'ver' command in matlab commnad window.
Message 3 of 10
(6,515 Views)
Hi DaqProblem,
You are using the correct command to open the Matlab GUI (as discussed in KB 3Q56TJL2) although the interface is limited.  The Matlab script node simply calls the Matlab Script Server and is limited by the functionality this exposes.  There are also possible problems because you have multiple versions of Matlab installed.  Check out KB 2A6E3SDM for more information on this.  Uninstalling the version of Matlab you are not using might help.
I hope this helps!
Megan B.
Message 4 of 10
(6,502 Views)
Hi
Try using run command instead, like
run('yourmfile')  %the name of the m-file without .m. Remember to use ' '
or take at look at my post here
https://forums.ni.com/t5/LabVIEW/calling-Matlab-GUI-from-Matlab-Script-Node-causes-Labview-to/m-p/61...
Hope it works
Simon
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
Message 5 of 10
(6,306 Views)
Hi
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=284468#M284468
Hope it works
Simon
VBAI 3.6 / 2010
Message 6 of 10
(6,306 Views)
Message Edited by SCMAJA on 11-15-2007 11:29 AM
VBAI 3.6 / 2010
Message 7 of 10
(6,306 Views)
Hi
Hope it works
Simon
VBAI 3.6 / 2010
Message 8 of 10
(6,306 Views)
SORRY about the many posts. By browser went crazy 😞
VBAI 3.6 / 2010
Message 9 of 10
(6,305 Views)
The right way to call a GUI in command line is GUIname(), before which you must ensure current path is correct so that matlab can find the mfile of GUI
Message 10 of 10
(5,434 Views)
