Matlab & Labview - portability
Hello everybody
I have a Matlab script in Labview, but I want to create Labview
standalone application. Is it possible to run it without Matlab
installed? Maybe I can migrate to HiQ easily?
Thank you for help
Best regards
PP
(2,816 Views)
To use the Matlab script requires the installation of Matlab on the target computer. The ease of migrating to HiQ will depend on the functionality you require. Make sure you check this out in the HiQ help. You might also be able to develop a purely G code instead of using the script nodes.
Marc
(2,816 Views)
