Matlab command window text font under Windows 10
For quite some time I use LabView 2012 for aquisition and via a Matlab script window I transfer some
data to the Matlab Command window as it appears opened by LabView.
It worked fine. But under Windows 10 on my new hp840 laptop and a 27 inch monitor the fonts in
the command window are very small, practically not readable.
??? Does anybody know where this font size or style is set and can be changed. I tried a lot. E.g. in
the full Matlab there are "preferences" where this can be set for the Matlab owned window, however,
the LabView owned window is not affected. Probably LabView has same default setting.
Thanks for an answer
KG
Message 1 of 1
(3,107 Views)
