Matlab plot integration and interaction on a front panel
Hello all,
I am making slow progress in the direction I have taken and was wondering if anyone had some experience/ideas with this. In my application I have the need to mesh a grid optimized to the geometry defined by several boundary points. For this purpose I found a MATLAB code developed by MIT which I would like to use. Right now I can define these boundary points in Labview, then call the matlab exe with this information and have the meshing code come up with a grid. I can get the grid point coordinates back to labview, but here is where the problems start. I am looking for a way to plot these discrete points, not as a curve but as separate dots or 'x'. Also, I would like to be able to click on a point and have Lab View read that points coordinates and store it in a variable.
I assume there would be event structures involved, mouse click event, something like that, so I will be experimenting with that in the meantime, but right now I do not know how to even plot my points.
Thank you advance.
Alek
(4,851 Views)
There are a number of examples that ship with LabVIEW to show you how to do plotting. Open the Example Finder (Help -> Find Examples) and in the tree select Fundamentals -> Graphs and Charts. Also take a look at using cursors for graphs, which will give you coordinate values.
Stop back when you've had a look at those and have a better idea of what you need to do.
(4,834 Views)
