Matlab script on the FP-2000
hello,
I use a script matlab with LabView RT, which I download on my FP-2000. When I carry out my VI, I have the following error : Failed to load script support dll from c:\ni-rt\system\script. in essai.vi.
Why my script of test (a=12 and I post a) does not walk on the FP-2000?
Thank you
(3,078 Views)
It's not currently possible to run MATLAB scripts on a LabVIEW Real-Time target. When you use a MATLAB script in LabVIEW, it calls the MATLAB engine on the PC. Since the MATLAB engine can't run on the Real-Time Operating System, you can't interface with it to run the scripts. The error you see is expected.
Dafna Livni
(3,078 Views)
