Matrix Multiply slower on RT than PC?
Doh.  Again with going too fast.  The picture below explains why all results are the same and parallelization did nothing.
Apparently, I can't subtract.
Message 11 of 14
(1,090 Views)
Yes, I mentioned it. 😄
I recommend to use "high resolution relative seconds", because you get a negative value if you subtract wrong. Easier to notice. 😮
(You also get finer resolution and the results are in seconds instead of ms.)
Message 12 of 14
(1,083 Views)
To do some math-intensive work, am trying to figure what would be an optimal configuration to purcahse.  The speed-up between Parallel FOR loop (4 cores) and Parallel FOR loop (32 cores) is only 2x.
For matrix multiply, is there a LV bottleneck for regarding the physical vs. virtual cores?  Given that your machine has 8-cores/socket, might the speed-up correspond to one-socket and physical cores?
Message 13 of 14
(800 Views)
Hi wjdwyer,
It looks like this thread is a little over a year old, and your question is a bit different than the original question. I would recommend creating a new thread for your question, as it'll be more likely to be seen and answered that way.
Message 14 of 14
(778 Views)
