Matrix as input and output
Hey
I have a program with a matrix as output. I set the matrix and run the program. The program also saves the matrix settings to a file.
What I want is to see the last matrix state on the matrix when I start the program/labview. Only way I have seen so far is to make 2 matrix, 1 as output, and one for input.
But I want it to be one matrix, wich means it must be both input and output. Which seems imposible. Is there anyway I can do this or make it looks like one and same matrix all the time?
Jonas
(2,979 Views)
Sorry the matrix is a input to the program.
And i want to see the last setting off the matrix each time I start labview
(2,970 Views)
Hi Jonas,
I'm not sure I really got your point but it sounds like a "make current value default" on your matrix control would do the job. If at the end of your VI's execution you perform a make current valur default, you will get this value the next time you start the VI, is that what you need ?
If yes, LV 8 as this feature built in, and for previous versions there are some tricks that you will find following this link 😉
Hope this helps you Jonas.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,970 Views)
Thanks for reply.
I solved the problem by creating a property node. The program writes to file so while it runs it reads from file - Deletes file - Writes a new file, of the setup. Organised in sequens struckture.
Since the "make curren value default" function in 7.1 only made the current, and not the last default. I had to use file as memory for it.
(2,953 Views)
