Max Copy Configuration Replace problem
I want to use the MAX Copy Configuration.vi to import a configuration file into MAX to replace whatever configuration it has. My configuration file only contains one VISA TCP/IP address. However, when using the "Replace" as the input to the "replace mode" input on the VI, it does not delete the other VISA TCP/IP resources. It will add mine as if it were doing a merge.
In addition, if I have MAX setup so it has a VISA TCP/IP resource with the same alias as the config file but a different IP address, when I run the MAX Copy COnfiguration vi it will create the correct resource with correct alias and IP, but an additional VISA resource will be present with the alias "TCPIP0:<old IP>::inst0:INSTR" and the old IP address. Is it not possible to do a replace with VISA TCP/IP resources? See attached VI and .nce file.
Michael
(3,314 Views)
Michael,
Unfortunately, the released versions of NI-VISA only support 'merge' mode when copying configuration. We will try to add that feature to the next version of NI-VISA. Be sure to check the readme for the new features when the next version comes out.
Thank you,
Pankaj
(3,312 Views)
