Max Number of Labview objects
How much objects can be placed in Labview V7.1 ?
(3,106 Views)
There is no specific limit.
It depends on what kind of objects, and how much RAM your computer has.
In 15 years of LabVIEW programming, I have never encountered a problem concerning too many objects.
I have run out of memory when slinging 50 MByte arrays around, but not in the code itself.
Steve Bird
Culverson.com
LinkedIn
(3,106 Views)
I think your are not right. When i use more then 570 objekts i got the following error message:
D:\lvworm\src\mgsource\image.cpp(12443) : DAbort: bad image in ValidateImage
$Id: //labview/releases/7.0/mgsource/image.cpp#1 $
The labview program crashes and is not startable again.
(3,106 Views)
What sort of "objects" are you counting?
Steve Bird
Culverson.com
LinkedIn
(3,106 Views)
Now this is interesting!
The main limitation in LV is the hardware as Coastal... has pointed out. That limit will always be with us.
There was a limit of 550 front panel object in LV 6.1.
But I understood that that limit was lifted in LV 7.0. I may have read that in the release notes, not sure.
BUT...
That erro you reported starts with "lvworm" which I believe is associated with LV 7.
Ben
(3,106 Views)
