Max Tasks to not show up in the tree
I don't know if this is the right board or not, but there isn't a MAX board.
I am having a problem in Max where I can create a Task, Save it and it doesn't show up in the task tree, However I can access it in the browse window in Labview. I have attached the 2 images below to show the problem. Thanks in advance for your help
(2,768 Views)
Accepted by topic author griff32
This sounds like a MAX Database corruption problem, the following link has steps on how to fix a database corruption:
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9?OpenDocument
Let me know if that works for you.
Nathan P.
(2,726 Views)
Thanks Nathan that fixed it. I may mention for anyone that has this issue, to export your NI configuration file (.nce) before you reset, and then import the file after your PC reboots.
(2,711 Views)
