Max & Min value for each columns
Hi!
Can anyone help me modify my. VI? I want to get Min and Max value for each column of Appended array. Then I need to create two 1D arrays - the first with the min and the second with the max value.
(3,148 Views)
Accepted by topic author Slizeer
I already solved the problem Smiley Happy The solution is below
(3,146 Views)
Your code is exceedingly complicated for such a simple task. All you need is this:
(see also here)
(3,131 Views)
