Max binary or TDMS file size to read (64-bit)
Thanks for replying.
The data acquisition program we are using has two blocks. One block uses DAQmx to collect the image information. The other one uses high-speed digitizer (NI-SCOPE) to collect the time informaiton. The TDMS file is used inside the digitizer block. Could I ask another question? Does NI-SCOPE have the similar function, for the digitizer part?
Message 11 of 16
(1,515 Views)
High speed direct logging to TDMS is only supported by DAQmx driver calls.  You'll have to read the data and store it using the TDMS primatives.
Message 12 of 16
(1,509 Views)
After we get data from the NI-Scope, they are put into a queue, and the TDMS accept data after dequeue. We also need to do a little bit on-line analysis after dequeue, which is parallel to the TDMS data recording. So this is not a direct case? High speed direct logging to TDMS will be much faster than this way?
Message 13 of 16
(1,498 Views)
I have not done any speed test.  But NI claims that by using the DAQmx logging that the speed is faster than performing a read, and then a TDMS write.  I've heard some at NI claim this opens a DMA channel from the hardware to the disk drive, and "doesn't involve the CPU".  I'm not certain that particular NI person knew what they were saying but my take away was, that it is about as fast as you can get.
That being said TDMS in general is very fast for writing data, and even using the read DAQmx, then write TDMS should be pretty quick.  It's on reading TDMS data that can be slow depending on how efficiently it was written.
Message 14 of 16
(1,477 Views)
Thank you very much. As a beginner, I should learn more on Labview and do more test to find the answer. Thanks for your suggestions.
Message 15 of 16
(1,465 Views)
We were all beginners once, feel free to ask questions.  At the end of this document is some free training if you are interested.
https://decibel.ni.com/content/docs/DOC-40451
Message 16 of 16
(1,455 Views)
