Max voltage level
I am using the DAQ assistant to take in a signal and I need to display the maximum
voltage that signal has reached. I was trying to use the 'write/read to
measurement file' vi to save the maximum value and then compare it to the
current value. Could anyone tell me if there is a simpler approach.
Thanks in advance
(3,182 Views)
Hi
Take a look at this simple example. Does it help at all? If not please can you post back with a little more detail of exactly what it is you are trying to acheive.
Rich   NI | UK
(3,158 Views)
Rich:
Your example did not attach
-AK2DM
(3,152 Views)
Sorry, here it is.
Rich   NI | UK
(3,150 Views)
