Max6675 for k-type thermocouple temperature reading using arduino and labview
Hi; I am trying to measure temperature using arduino mega +labview 2013 +k-type thermocouple+max6675.
I am using LIFA interface.
The circuit digram  and labview file is attatched
I am stuck on spi read/write palet. How to read 12 bit max reading and convert it to temperature in degree celcious?
Max6675 produce output in 12 bit, and measure 0-1023 centegrade. According to this the
Temperature (C0)= max6675 output (12bit)* 0.25. how to set this formula in labview?
Pin connections are
Max6675 breakout board pins
Arduino Maega Pins
GND
GND
VCC
5 VOLTS
SO
50
CSK
52
CS
12
(10,998 Views)
You need to convert the string you get into an integer (i.e. Scan From String) and then you can apply the scaling.
If you continue to have problems, provide the exact string that you get back.
(10,979 Views)
thanks for you responce
acctualy i am new to labview. can you plz guide me which functions i use to get the temperature reading. after the ISP read write palet?
(10,969 Views)
Sorry, I misunderstood you. I thought you had code that already read the arduino. I don't have one.
(10,965 Views)
Hi Saeed780,
We have a discussion board specifically for questions about using the LabVIEW Interface for Arduino. Can you please post your question to the Arduino board?
www.ni.com/arduino
Catherine B.
(10,907 Views)
Hola que tal buenas, tengo el mismo problema o duda que tuviste en tu tiempo, no se si pudieras apoyarme a resolver ese mismo problema, quiero usar el termopar k y el max6675, usando interfaz arduino-labview, de antemano muchas gracias.
(6,408 Views)
Hola pedro_16,
Dado que éste foro tiene ya un par de años, te recomiendo colocar tu pregunta como un tema nuevo en los foros dedicados al uso de Arduino en LabVIEW: LabVIEW Interface for Arduino Discussions
Si prefieres soporte en español, puedes preguntar en la comunidad hispanohablante: Discusiones sobre Productos NI
Mucho éxito en tu proyecto! Un saludo,
(6,396 Views)
