Maximize window
Hi, I woudl like the front panel be Maximized when I run the application. I take a look at the Window appearance, I don't see any option to maximize when run, could you please let me know how can I Maximize the window and which property I shoudl change
(3,665 Views)
(3,661 Views)
You just need to change the VI properties
Open the VI --> ctrl - I --> windown run time pos --> Maximize --> Ok
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,630 Views)
Ranjeet,
Why the message?  You just told exactly what the message above yours said, 12 hours ago.
(3,626 Views)
I simply didn't see that. I was doing someting else. I saw question and replied. My chrome is Zoomed at 200% hence I cant see what is the previous reply.
Now I saw both are same Smiley Very Happy Can't remove now
--Ranjeet
(3,620 Views)
