Maximum control value
I have got a (dbl) control on my vi that may not exceed the value 0.1. Is it possible to do this?
I would think this is a pretty easy question but I couldn't find the answer to it.
Cheers
(3,614 Views)
Right click > Data entry
Tim Elsey
Certified LabVIEW Architect
(3,611 Views)
Right click and select 'Data Entry'.
On-line help - Numeric>setting ranges.
(3,610 Views)
hello,
yes right click on , select diplay format, and go to data entries then uncheck use default limit box and set as you want
regrads
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,607 Views)
I shudder when I hear DBL and '0.1' in the same post.
(3,600 Views)
Accepted by topic author gbvdh
maybe step is 0.00000001  !
(3,593 Views)
