Maximum entropy spectral analysis in Advanced Signal Processing Toolkit ?
Is Autoregressive Spectrum VI from LabVIEW Advanced Signal Processing Toolkit  synonymous with the so-called  Maximum Entropy Spectral Analysis method?
(3,617 Views)
Hi Fedor,
By Autoregressive Spectrum VI, do you mean "TSA AR Spectrum VI"  found in the Correlation and Spectral Analysis palette?
Also, when you say "synonymous" are you refering to the duality between maximum entropy method of spectral analysis and autoregressive (AR) representation of data as described in this article?
Mikhail
RF Toolkits, Product Support Engineer
(3,590 Views)
