Maximum number of plots allowed in a waveform chart
Hi
I am working a process monitoring application and need plots for around 850 parameters, around 10 plots visible at one time depending upon user preference.
I am using a waveform chart but it does not allow more than 700 plots.
Any tips would be welcome.
(2,102 Views)
Hi nustian,
I would use a graph instead and only create/show the plots as selected by the user...
(2,096 Views)
@GerdW
Hi
Thanks for the reply
is there a workaround the problem using a waveform chart?
Regards
(2,092 Views)
I would create an array of 850 buffered waveforms ( holding say 1024 points each or whatever your chart history length is set to).   Then, simply extract the selected indices and write selected plot names and the whole data history via property nodes (use defer the FP Updates method or the redraw will lag badly)
At which time you probably wrote a pseudo chart and could use a graph just as easy except for needing to change the buffer code for rolling, sweep and oscope display modes.  Those display modes are the likely culprit for the chart limitation.
(2,079 Views)
Graph would be easier but I do require the history of plotted variables,
(2,026 Views)
A Map of <signal name, wfm buffer> would make some sense.  Or, assign the wfm name in the wfm attributes.  Either way you're searching a red black tree to return array of wfm buffers to display rather than searching for a sparse TRUE in the plot visible propery of each plot to maintain the visible plot name history.
(2,021 Views)
