Maximum value in control design and simulation loop
I am trying to determine the maximum value when running a CD and Simulation loop. I know if using another type of loop, I could use a shift register and continue to build an array, but I can't seem to form a shift register with the CD and Sim loop. My CD and Sim loop has 100 iterations. Is there any way I can log all 100 values into an array?
Message 1 of 9
(5,363 Views)
Did you try using the build array function?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 9
(5,361 Views)
So I should probably have mentioned that I am a labview novice....
If I use the build array function  inside of the CD and Sim loop it will only store the last value. I have verified this bychecking the size of the array and it returns a value of 1.
Message Edited by peeroe on 09-23-2009 09:04 PM
Message 3 of 9
(5,355 Views)
can you post your vi or a sample of your vi?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 9
(5,351 Views)
I have posted the VI. The value that I have labeled as "VITAL VALUE" is the one that I am trying to get the maximum for. It is displayed on the graph in red.
Thanks!
Message 5 of 9
(5,349 Views)
could you post it as 8.6?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 9
(5,346 Views)
Ooops,
Sorry about that. Hopefully this one will work a little better.
Message 7 of 9
(5,344 Views)
hi guys .. didnt found any relative thread to post my problem hence posting here only... sorry for that.
i want to take an output value out of the simulation. is it possible?
Message 8 of 9
(4,842 Views)
Hi JUSTBEGINE,
Since this thread is older, you would probably be better served creating a new post for issues like this in the future.  As for your immediate question:  Yes, you can pass a value out of a Control & Simulation loop like you'd pass any other value out of a loop in LabVIEW.  If you're unfamiliar with how to do that, here's some getting started information about using loops in LabVIEW:  https://www.ni.com/en/support/documentation/supplemental/08/labview-for-loops-and-while-loops-explai...
In addition, you should be able to find examples in the Example Finder (Help >> Find Examples >> Control and Simulation) regarding how to do this.
Matt | NI Systems Engineering
Message 9 of 9
(4,833 Views)
