Maxon epos error code reading
Hello All
I'm programming a maxon EPOS 24/5 with Labview 14. I use the Vi library from maxon. My problem is, when i want to read out the errors with the 'VCS get device error code' i don't get the right codes. I always get a Code which has five numbers (like 34321), but in the EPOS command library (where the error codes are described) all codes have eight numbers (like 1000 0003). So i don't know which error i get. Does someone no another table where are the errors described?
Thanks for answers
(6,210 Views)
Hi Peter,
I would recommend you to contact Maxon for that information since it is their information and it is not really a LabVIEW question in the stricter sense. Perhaps you are lucky that another user stumbles upon your thread and happend to have this kind of information, but I wouldnt bet on that.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(6,186 Views)
Hi Christoph,
I have also contacted Maxon and they gave me another list with the detailed Errorhandling.
Peter
(6,179 Views)
Hi Peter,
thank you for your examplary response!
It's always nice if people do not just write that they solved it, but HOW they solved it, so other users can participate from their findings.
Christoph
(6,163 Views)
