May I ask how to implement this logging function so that every step of execution is recorded in log.txt
Is there any expert who can write a demo for me to learn from
Message 1 of 11
(924 Views)
Every step from where?
This looks like a communication log for GPIB or VISA.
Santhosh
Soliton Technologies
Message 2 of 11
(908 Views)
yes,How can I add the SCPI instruction to the log
Message 3 of 11
(896 Views)
By writing the string to the log file!
What's the problem?
Message 4 of 11
(880 Views)
Could you write a demo for me to learn from
Message 5 of 11
(877 Views)
You want me to place a WriteTextFile function on an empty block diagram?
  • You should know how to write data to a file.
  • You should know how to use subVIs (or a QMH) to handle data/messages.
  • As you want to write "every step" you need to write "every SCPI message" to your log file...
Message 6 of 11
(857 Views)
Yes,I want to write "every step" you need to write "every SCPI message" to your log file...
Message 7 of 11
(853 Views)
Where did you got this log are you able to get the read SCPI data from your DUT?, Is the problem is only with Logging in the above format?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 8 of 11
(827 Views)
use a function write file everytime you call visa write.
Message 9 of 11
(815 Views)
The logging function of C#
Message 10 of 11
(794 Views)
