May I do a installer in Labview Evaluation Mode?
Hi all..!! i have recently installed Labview 8.2 and I need to create an installer but I am not sure if I can do that in evaluation Mode...my dude is if after 30 days i will be available to still using my installer...thanx in advance for all replies...!!
(3,544 Views)
your dude is after 30 days?  What does that mean?
I think you can't make an installer with the eval copy.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,516 Views)
Actually, you can make an installer with the eval version. The app will still display the "Evaluation" watermark, but once you have the application I don't think you would run into the 30-day limit since the Runtime Engine is used to actually run the app, and not the LabVIEW development environment, and the LV runtime doesn't have the activation requirement.
(3,510 Views)
I defer to smerc's vast wisdom.  🙂
-Matt Bradley
(3,502 Views)
thank u guys for your reply..!!! i could to registrer my labview version whit NI code..so i will try to make the installer again and i think it will not fail in the future...anyway i think that smercurio is right however the watermark is really irritating
(3,459 Views)
Accepted by topic author Sapingo
Sapingo,
Check out this KnowledgeBase. It shows the limitations of the Evaluation Versions of LabVIEW.
Jon S.
LabVIEW NXG Product Owner
(3,454 Views)
thanks Jon..!! that was really usefull..!!
(3,440 Views)
