May I receive resolution 640*480 in image LV from WEB-camera
Hello all
I have LV7.1.1
I received the image from WEB-camera.
WEB-camera has resolution 640*480 but I have resolution in the Image of LV -  320*240.
May I receive resolution 640*480 in LV ?
With respect.
Aleksandr
Message 1 of 8
(3,183 Views)
I assume you have to change the settings of the camera and not the code in LabVIEW...
Just in case, see the attached code in LV 7.1.1 that allows to change the image resolution.
Hope this helps 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 8
(3,182 Views)
Dear TiTou
Thanks for the attention and the help.
I will be try.
Best regards
Aleksandr
Message 3 of 8
(3,178 Views)
Hi.
I have tried.
all work.
But  the Image are changed from 640*480 to 320*240 and then back.
Best regards
Aleksandr
Message 4 of 8
(3,159 Views)
Hello Aleksander,
Try creating a separate image buffer (with IMAQ Create) for the resampled image and connect an image display control to that image.  If you are only using one image buffer, your program is probably alternatively writing the original image and the resampled image to the same buffer.
Allen H.
Message 5 of 8
(3,135 Views)
Hello Allen H.
Thanks for the answer and excuse me for my long  silent.
I will be try
Best regards and lucky
Aleksandr
Message 6 of 8
(3,130 Views)
Hello Allen H.
I did so.
But image is changed steel.
I don't now what do I do?
Best regards
Aleksandr
Message 7 of 8
(3,107 Views)
Alexandr,
Do you think you could attach a copy of one of the images you are trying to open in LabVIEW?  I would like to try and recreate what you are seeing.  Thanks.
Jason N
Message 8 of 8
(3,050 Views)
