Measure Frequency/PWM with NI cDaq-9178 and NI 9403
I need to measure the frequency of the digital signal with the range 0-5V, I am trying to use the NI cDaq-9178 and NI 9403 ( DIO only) for this purpose, but i could not do, I could see some example but I only found using NI hardware with counter´s but in my reasearch i could see that this two hardware don´t have, Its possible to do this using this method or I am doing in a wrong way?
(1,231 Views)
(1,197 Views)
Even simpler, to get started, try out some of the shipping examples for counters.
I don't do a lot of cDAQ stuff, but you'll find that:
1. your cDAQ chassis contains internal counters
2. those counters can interact with signals on your DIO module.  Counters can measure stuff coming into a DI channel or can send stuff out a DO channel that it generates internally.
3. the drop-down menus for specifying the cDAQ "terminal" to use for the measurement will let you self-discover the right syntax better than I can try to recite from memory.
The previous link will also get you to some good stuff, but it's more advanced.  It *does* illustrate a generic version of the channel and terminal syntax, but on your own system some of the names might be different.  Still, the pattern will at least be analogous (for channels: "Device/channel",  for terminals "/Device/signal".  Note the leading '/' forward slash in the terminal syntax.  But the drop-down menu will show you this too.)
-Kevin P
-Kevin P
(1,164 Views)
