Measure TTL signal also when frequency is low or 0
About the amount of counters used.
X-series cards (63xx cards) can indeed create a finite pulse train with one counter (STC3-type).
M-series cards (62xx cards) have counter of the STC2-type.
Here you'll need 2 counters to create a finite pulse train:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7eESAS&l=en-US
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 15
(681 Views)
I have an M-card (6259e), and I'm using two counters, one to generate a finite pulse train (ctr1), the other (ctr0) is counting edges between the rising edges of ctr1.
The counting is working just fine, except I get the cumulative values while I want the individual counts per bin. Currently I'm solving this ins software, but I would prefer the card to do it.
Message 12 of 15
(655 Views)
Ow sorry, let me recapitulate.
I forgot one important part in my sentence (must have been a bit off-guard while writing it).
I meant a finite retriggerable pulse train.
My apologies for the inconvenience.
Kind Regards,
Message 13 of 15
(652 Views)
I didnt have this problem, I used 3 "old style counters" on a 6608 counter card.
I made a retrigerrable finite pules train and then a simple continious buffered (NOT FINITE) counter on the 3rd, newer devices (X series) can do this in 2 I think.  This way on each event trigger I was able to get an array of N bins of defined duration.  Maybe the finite counts are what is causing a problem?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 14 of 15
(640 Views)
Hey Paul,
A bit off-topic to the question, but I would like to give you some further details about the counters.
- 62XX devices use STC2-counters
- 63XX devices use STC3-counters
- 66XX devices use TIO-counters/chipsets (again a different type 😉 )
So what you saw/experienced is perfectly possible.
I cannot test it currently (with real hardware), but I can do a test tomorrow at the office if you would like that.
Kind Regards,
Message 15 of 15
(635 Views)
