Measure an Angle in a image
this is a  nozzle,I want  to use labview automatic testing the angle.
  can you help me?
thank you very much.
(4,788 Views)
I don't even think this is a LabVIEW question... yet.  Do you have a general idea of how to approach the issue, yet?
Bill
CLD
(Mid-Level minion.)
(4,764 Views)
设定一个阈值,把图象转化成黑白.
在三角形中不同的高度,测定宽度二次.
利用宽度和高度的差, 三角函数算出顶角.
George Zou
(4,758 Views)
billko 已写:
I know use vision kit  can solve.But I don't know how to implement the specific.
(4,718 Views)
Generic answer to you is to use IMAQ Lines Intersection VI or IMAQ Get Angles VI.
-The first VI requires two lines each a cluster of two points defining the line.
-The second VI is also similar but instead uses points directly.
-To get the points you can try using the one of caliper tools to detect edge points.
uday
(4,697 Views)
