Measure contrast of image in real time
Hi, im working in a project with a microscope with a camera and a positionig table. I want to make an autofocus and i have read that it can be made with the contrast of the image but i dont know how i can get the contrast of the cameras image. I´ve the vision adquisition extension.
Thanks.
(1,914 Views)
As I understood from description You need to build a vision application where the distance from the camera to the target is changeable. You can determine the best focus using software. Basically, take a series of images at different focus positions and analyze them to determine the best focus. Typically, the analysis is an edge detection followed by an image quantification. You can look at the mean value or the standard deviation of the edge intensities, and a peak value is the best focus.
And also You can find info about Detect Quality of Focus on a Camera here.
(1,828 Views)
