Measure period and pulse duration of ttl level continuously
i want measure the period and pulse duration continuously of two signals with an usb-6009. Every 8s there is a high pulse for 15ms. I want to measure length of the pulse and  pause. Can someone help me? I can`t get a start up with this problem.
The four measurements (two channels two measurements per channel) are a dataset. This dataset should be stored in a textfile continuously. But this not a problem.
thankyou
Schwede
(3,434 Views)
Hi Schwede,
Thanks for the post!
I had noticed you've received no replies.. but as Im out of the office until tomorrow, I will look into this in more detail.
However, I can talk a bit now:
So ideally you would use the hardware clock in DAQmx tasks to measure the pulse - there are examples in the example finder (Help>>Find Examples>>Hardware I/O>>DAQmx...). However, Im pretty sure this will use two counters (At least 1! per channel). The USB 6009 only has 1 counter.. you wont be able to do it for two channels...so Im not sure you'll be able to resolve your issue this way.. I do need to confirm this tomorrow mind you!
So secondly you could do this in hardware, by sampling the channels and having code to detect a change of state and then to time this period - i.e. Measure the length of the pulse. I have an example of this, on my office machine.
So I'll post a more detailed reply tomorrow at some point.
Kind Regards,
Message Edited by Hillman on 10-15-2008 09:29 PM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,403 Views)
i have tried to measure the signals analog, but i can get an solution. The problem is to measure continuously and store the period an pulse width at the same time.
can anybody help me? Examples?
greetings
schwede
(3,363 Views)
 Hi Schwede,
Thanks for the update - Im now back in the office!
I have some bad news, your using the wrong device - you need a device with at least two counters - to acquire for two signals. But, secondly,(see specs), the counter measurements support by the USB 6009 doesn't include pulse or width measurements.
The specs for the USB 6009:
Counter
Number of counters ................................1
Resolution...............................................32 bits
Counter measurements ...........................Edge counting (falling-edge)
To acheive the functionality you require I would recommend a USB 621x:
Number of counter/timers ............... 2
Resolution ....................................... 32 bits
Counter measurements.................... Edge counting,
pulse,
semi-period,
period,
two-edge separation
Also, this link is rather useful also:
How Many Counters Does Each Type of Counter Input or Output Task Take?
http://forums.ni.com/t5/forums/replypage/board-id/170/message-id/363123
Please let me know if you have any other questions.
Kind Regards,
Kind Regards
James Hillman
(3,354 Views)
