Measure with Keithley 2000 over RS232
Hey,
ich have a problem with my Keithley 2000 by measurements over RS232.
My programm is running, its a simple serial read and write VI. I send him an command to measure and nothing is happening. I got nothing back....
I add the VI and the commands, maybe somebody knows whats wrong with my VI!
Thanks a lot
Greetings
Ralf
Message 1 of 56
(12,408 Views)
I have no time to look into your code, but most likley you miss the termination char. On a string constant you can switch to \-display and then use \n or \n\r depending on the settings. You can also look into the LV drivers for the keithley 2000, they are available on ni.com and/or on keithley.com
Felix
Message 2 of 56
(12,388 Views)
thanks for your help.
know i get the error: timeout expired before operation completed. whats the reason for that error?
Message 3 of 56
(12,381 Views)
I guess that is comming from the read. Does it return any data?
There is a VISA property node for the timeout, so you might increase it. If you use the serial port open vi (I don't heve the name correctly), there is also a timeout to specify.
Felix
Message 4 of 56
(12,371 Views)
yes its  caused from the read function...
if i increase the timeout its still not working, i think the read does not work because its not able to get data back. the question is why does the read not work?
Message 5 of 56
(12,369 Views)
I just took a look on some old code of mine. After writing READ\n I wait 100 ms. Then I use the Property Bytes.At.Port for the read function. Generally using some waits helps when programming RS232.
Felix
Message 6 of 56
(12,359 Views)
The read does not work because the write is wrong. Your code does not send a termination character as already mentioned and you are not doing a query. Your image shows a MEAS command but you are not doing that.
Message 7 of 56
(12,356 Views)
im using a wait function, thats all running...
i think something with my writing is not correct....i send the command
:READ\n;
nothing is comming back, the keithley 2000 is working with SCPI commands, i tried to use them but its not working...
whats the correct syntax, maybe i messed something up....?
thanks for your help felix
Message 8 of 56
(12,352 Views)
READ\n is not correct either. You HAVE to follow the syntax that is in the manual. You HAVE to send the ? like the manual shows and you have to set your string constant for '\' Code Display.
Message 9 of 56
(12,348 Views)
okay dennis, i know what you mean, i tried to do this, but whats the correct syntax?
*IDN?
:MEAS:VOLT:DC
Message 10 of 56
(12,344 Views)
