Measurement Computing VIs
I have used Measurement Computing's I/O boards in my systems for over 6
years. My LabVIEW applications,
containing the Measurement Computing VIs and running under Windows 2000
Professional have worked without
any problems. The applications are built on a system running Windows XP
professional. The MCC VIs run
with no problems in the developement system under Windows XP Professional,
but when the built application
is run on a target system running Windows XP, the application hangs when it
encounters the first MCC VI which
is usually an analog input VI.
Has anyone else encountered this problem ?
Joe Vieira
(2,832 Views)
Joe Vieira
I've successfully used Measurement Computing's USB thermocouple box under XP in both Development and as a built application without encountering the problem you describe.
If you could post your code, or a cut-down version demonstrating the problem we can have a look at it. Also could you let us know what version of LabVIEW you are using.
Tim Norris
"...and all this science I don't understand
it's just my job five days a week"
Using 6i, 7.0 & 7.1 on Win'98, 2K & XP
(2,800 Views)
