Measurement and Automation Explorer and NI-DAqmx
When I install the second CD ( Device Drivers) of Labview student version 7.0 Express, after installation it does not show the NI-DAQmx in the left hand side configuration window in the interfaces. During installation i had selected the DAQmx for installation. Without the DAQmx i cannot use the DAQ assist, so please help.
Thank you
Ujwal
(2,810 Views)
Actually I checked right now, and in the functions-->input--> i do have the DAQ assist but when I drag and drop it.....it doesnt have any terminals to be connected to...also i have DAQmx vi....which i tried to run and it says channel not configured....how can i configure a channel for DAQmx...as i cannot see DAQmx in the configuration when i go into the measurement and automation explorer....
Please help....
(2,806 Views)
If the DAQmx option does not show, then NI-DAQ driver is probably not installed correctly. You can download a copy by going to http://digital.ni.com/softlib.nsf/websearch/90b60d5899bcccdb86256fc700581b89 . You might be asked to sign in with your profile.
(2,780 Views)
